Model 81v40d. I replaced elements and thermostat. It heated fine once. Then the next day it went right back out.
Http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: heating elements do not operate together
That's how they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank
SOURCE: my rheem water heater does not stay hot for very
set top t-stat @140 and bottom @150 and see if that helps
SOURCE: The heating elements and both thermostats have
when you replaced them did you bleed all of air off tank before restoring power to w/h if not you could have burnt the new ones , are you getting 220 volts at top of w/h and ck wiring again to be sure properly wired top comes first and when has reached set point of top t-stat it transfers power to bottom just like a 3-way light switch operates 120 volts always on bottom waiting on the other side of the line to heat the element on 220
SOURCE: My hot water heater tripped the circuit breaker on
Tough problem here. Most dual element heaters share one line. if this is the case and you have power on the top and none on the bottom I would check the connecting wires one to another. also check the settings of the thermostats. They may be adjusted all the way down. If the wires and connections are good I would recommend ohm testing the new elements. I have burned elements out by introducing cold water to very hot coils (forgetting to turn the water on after flipping the breaker)
Never forget that calcium buildup will short the element. If touching on the bottom you will burn it up.
If this does not help try borrowing hot water from neighbors ;)
Good luck
Joe
Testimonial: "top element = O ohms, burned out. Replaced top element, turned water on and waited for tank to fill this time "Prior" to plugging in. THANKS!! "
SOURCE: how do i replace the heating elements of a rheem
Not familiar with this model but most are generic.
Turn the water off;
Release the pressure with the pressure relief valve and leave it open;
Undo the cold water inlet assembly and drain the tank;
Disconnect the element wires from the thermostat;
The elements are held in by 4 bolts. Undo the bolts and remove element;
Installation is the reverse of above.
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
