SOURCE: still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
SOURCE: trouble faxing and receiving fax from "Brother 575"
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not receive faxes.I have not voicemail. What can i do?
SOURCE: Trouble faxing and receiving fax from "Brother 575".
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
