Washing Machines Logo
A
Anonymous Posted on Jan 11, 2014
Thompson twin tub hose
How to Replace Ariston washing machine pump
5 Related Answers
Anonymous
  • Posted on Jul 11, 2008
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Anonymous
  • 236 Answers
  • Posted on Mar 16, 2009
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Anonymous
  • 236 Answers
  • Posted on Apr 05, 2009
SOURCE: Need Longer hoses for water inlet and outlet for Danby Twin Tub
get an adapter for both of the hoses to extent.
Anonymous
  • Posted on Jan 23, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 27, 2010
SOURCE: I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Ariston Washing machine has not finished its cycle, and now won't open
Many times it's that the unit hasn't drained completely, Check the drain hose from the where it goes into the house's drain all the way back to the washer's tub including the pump. (take out the sock)....lol
How to drain water from 5.5kg twin tub
Get a rooter and clean the drainer hose...
Get electricity to the drain pump and make it work , only one control is broken on it , the drain pump is still good... find and replace the faulty switch , probably the one that stops machine when lid is lifted... that switch is 1st to go and so easy to Unscrew Unplug and replace...
Ned a new drainage hosed for a centrex twin tub washing machine. Any help?
yes go to the manufactures website and request the spares department for the part from them eric
My ariston av61 washing machine is not draining and there is no obvious opening to drain it.
to drain a washing machine simply place the drain hose lower than the tub and the water will run out
the reason it is not draining is that the pump under the tub is not getting power to start it or the pump is failed ( something jammed in the impeller like bobby pins bra wire , buttons or coins.)
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Washing machine does not empty
see the causes and use the common sense, God bless you.
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
1helpful
Washing machine not draining water
Hi.
Disconnect power, then move the machine forward and check the drain hose at the back of the machine. Check if the hose is kinked or blocked and check that the hose height setting is as from manual. If the hose elbow is set at incorrect height the water will be siphoned back inside the tub.
Access the drain pump filter (this is located behind front-bottom access trim or door ). If there is blockage in there the water will not be drain completely. Remove trim, unscrew the cap and be prepared to collect water. Ensure that power is off. Remove any blockage in there.
lean or replace the pressure switch and the rubber hose connected to the pressure switch. This device detects water level and stops drain when there is no more water.
If all that does not help, then the drain pump itself must be tested. In some rare case the main control module may be defective. Test all the rest first.
The problem is usually given by blockage, drain hose or by pressure switch.
Regards.
Ginko
4helpful
2answers
Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
1helpful
2answers
Leaking washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
