This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
This is not a "partial cup" problem and it is not a descaling issue. The root cause of this problem is electrical.
SOURCE: my keurig says its brewing but nothing happens.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: The Keurig is heating up the water, yet is does
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker.
Keurig
heatman101
