Pioneer AVH-X2500BT Logo
A
Anonymous Posted on Dec 24, 2013
Bluetooth error-10 I just went to make a call with the bluetooth and got the error-10 message.
1helpful
Bluetooth on nikon d3400 greyed out how do I get it on
From this forum:
https://www.nikonforums.com/forums/topic/7492-bluetooth-this-option-is-not-available-at-current-settings-or-in-the-cameras-current-state/
I had this exact problem with my new d3400 as well. My settings originally showed Bluetooth ON and when I clicked on it, it showed a couple options: Network Connection-ON, Paired Devices, Send while off-"ON". I clicked on Paired Devices and it showed that it had connected to my phone today (even though my connection to snapbridge was unsuccessful) - so in an effort to retry my snapbridge connection I deleted my phone from the paired devices and this caused the Bluetooth on the camera to completely turn OFF and grey out. Same problem everyone here seems to be having where I couldn't even re-enable the bluetooth again and just saw an error message saying "option unavailable in current setting".
Alas, I found a solution - I have an iPhone 6 so for me at least this worked:
I went to bluetooth settings on my phone and went to the camera name and said "forget this device". I then deleted the snapbridge app and redownloaded it.
Then I went on the camera and tried to do the "connect to smart device". Instead of going to snapbridge, I went to my phone's bluetooth settings and chose the camera once the name popped up again. It prompted a pair message and I had to confirm the # on the camera matched the # on my phone. It then paired successfully and the bluetooth on my camera was back on! -- (disclaimer.. while this was great to see that at least the bluetooth was on again, this did not resolve the issues I was having with snapbridge - I still can't seem to get it to connect through the app, but perhaps it will work out for others..)
When I go to my devices and look at my default printer it shows default,paired. I can't print... keep getting the error message
What exact error message are you getting?
If you are running windows 10 you should remove the printer from the devices list then pair it up again. For some reason on windows 10 you have to do it this way every time you restart windows.
2answers
How to recover error E:62:10 on Sony DSC T30?
Just did what "dcamille84" said to my Sony DSC-T30 and the error message went away - CRAZY! Unfortunately, I already bought a replacement camera though (was only 100 bucks new).
Error message 6c10
Close the Inner Cover
Close the inner cover to resolve the error condition.
Inner cover open 1
Inner Cover Closed 5
Press the <Resume> button after closing the cover to resume printin.
Also
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Installation Problem...shouldn't happen, but it is.
hello,
I study your bluetooth and to find out that windows vista did not support that hardware..please communicate 3com for this matter. find details about your 3com is here: http://www.3com.com/products/en_US/result.jsp?selected=5&sort=effdt&sku=3CRWB6096B&order=desc
may this help;
melnavz
Englcdt.dat error message
Got the same VRR.2 ERROR message, but when I reset (hold 6 and enter and the same time for a few seconds) it went back to the main screen. Hopefully I didn't clear any important information!
Error 6a00 message
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Bluetooth
Hi
I like to inform you that Acer Aspire 5630 series has many submodels some of them them come with bluetooth. It will be better if you tell complete model number so conclusion will be more precise. Usually bluetooth device not found message comes due to absence of the BT device. you may confirm your laptop if it has Bluetooth device integrated by following link http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=511&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
if you confirm that if your coputes has no built in bluetooth you can buy an external USB Bluetooth device from local IT stores. Usually price $10-$50.
Hapy new year in advance.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
