SOURCE: Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
SOURCE: how do I add paper to my sharp EL-1750V
Download the Operation Manual for your sharp EL-1750V calculator from here:
http://www.sharpusa.com/products/TypeManuals/0,1083,16,00.html
Check the section "Paper Roll Replacement" (it has some images).
SOURCE: I cannot find the replacement roller for my Sharp
Try this for supply
10rolls and 2 ribbon at $12.99 Free Shipping
SOURCE: manual for calculator sharp el 573
My Sharp El-573 calculator is in scientific mode and nothing I do will put it back in regular arithmetic mode. Please tell me how to switch it back. Thanks for any help! Barbara
SOURCE: loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
