Our TV was working perfectly for 3 years, but now when we switch it on, the picture comes on for about a minute, and then the screen becomes mostly green and purple and covered in vertical lines. Sound still works fine. Very grateful for any ideas of what might cause this! Model is a Toshiba 32ZP38B i had same problem in past
SOURCE: Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
SOURCE: blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
SOURCE: Bright Green Vertical Line on Plasma TV
two options 1 check ur power moudle for burst or swolling filter capacitors & check the electrolytic power capacitor in the primary side of ur power moudle .
SOURCE: I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
