Initial set up with player worked fine. I have double checked the cables running between the TV and DVD player and all appear to be plugged in correctly, but the picture is in black and white and is quite grainy. I can't figure out how to correct
SOURCE: Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
SOURCE: Component Cable
Component video quality is better then Composite Video (yellow wire)
Of course component cable hook up will improve picture quality.
I connect my camcorder to the TV with regular RCA plugs (yellow, white, red). The camera RCA plug-in holes are in a separate compartment. I can see what I am recording on the TV if the camera power switch is pushed over to "camera". I do my recording. Rewind. Then I have to push the power switch to "off" then over to "VCR" , and push "play" on the camera in order to see the play back on the TV screen. See if your power switch has several positions. I hope this info. is helpful.
SOURCE: no owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port. Also you may have to connect additional sound cables from the DVD output to the TV.
