20 Most Recent Toshiba 19HLV87 19 in. LCD HDTV Questions & Answers
How do i change the input of my toshiba 19HLV87 without the remote?
Thread necromancer here: hold play and channel down.
7/7/2020 8:58:43 PM • Toshiba 19HLV87... • Answered on Jul 07, 2020
How to turn on HDMI without remote
check controls along border. might have one
5/22/2015 10:05:57 PM • Toshiba 19HLV87... • Answered on May 22, 2015
What causes a snowy picture when you turn it on?
Tuner fault. Before replacing it; check the antenna connection for firmness. If it is found OK, contact any service technician to replace the tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/30/2014 5:06:03 PM • Toshiba 19HLV87... • Answered on Oct 30, 2014
2answers
How do i turn on hdmi cable
run hdmi to the tv and the other end to your receiver
7/4/2014 3:55:51 AM • Toshiba 19HLV87... • Answered on Jul 04, 2014
Nofuncionael controlremoto
From what I can see from what information you have left, the remote does not work. Try a universal remote
5/19/2014 10:48:31 PM • Toshiba 19HLV87... • Answered on May 19, 2014
0answers
0answers
Need help programming a direct TV remote to a Toshiba TV
Here is the link to instructions on programming the remote.http://support.directv.com/app/answers/detail/a_id/1343/~/remote-control-programming-stepsI think the code for your tv is 12006
1/18/2013 11:34:16 PM • Toshiba 19HLV87... • Answered on Jan 18, 2013
How to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
9/3/2012 1:55:13 PM • Toshiba 19HLV87... • Answered on Sep 03, 2012
Toshiba 19hlv87 blinking
It is going on protection mode. Change the power outlet to some other that works. Try changing the input device to something that works. If it does not work, try switching off the TV manually, remove the plug after switching off the power outlet, wait for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
7/28/2012 5:32:50 AM • Toshiba 19HLV87... • Answered on Jul 28, 2012
My tv is zoomed in and the remot is lost so I can't access the menu to fix it is there a way to reset the screen to normal view.
Going to need an original remote to attempt to undo this--universal will of course not work for this issue.
4/4/2012 3:18:15 PM • Toshiba 19HLV87... • Answered on Apr 04, 2012
Take off stand 19
The owner manual should have this but a word of CAUTION: most sets require the set to be laid face down and up to 6 bolts removed---It is extremely important the screen not be forced on a hard surface when doing this as it can instantly be damaged/destroyed----if that is damaged it is fatal.
4/1/2012 3:24:33 PM • Toshiba 19HLV87... • Answered on Apr 01, 2012
Toshiba 19hlv87 turns off in 3 seconds
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.3_28_2012_5_29_30_pm.jpg
3/28/2012 5:29:38 PM • Toshiba 19HLV87... • Answered on Mar 28, 2012
How to connect my ps3
You would have to use the HDMI input with the PS3 to your TV, or if composite cables are available with the PS3, you can hook them to the composite inputs on the back.
6/7/2011 1:05:25 AM • Toshiba 19HLV87... • Answered on Jun 07, 2011
Toshiba 19HLV87 19 in. LCD HDTV Logo
78 questions posted
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
tv zoomed in remot lost 39 t access
  • Televison & Video
