Hello!
You said Safe Mode wopnt boot and you have a black screen, but that the D drive won't open? Do you mean the CD /DVD Rom drive won't open or the D drive in My Computer (Computer in Windows Vista and higher) won't open?
Are there any error messages on the screen? One thing you can try is to install the same OS or higher over the one you have installed now. If you install Vista or higher in this manner, the Install will create a folder called WINDOWS.OLD on the C: drive that contains all of your old files.
Hope this helps and good luck.
SOURCE: Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
hope this helps you
