20 Most Recent eMachines E620-5885 Notebook Questions & Answers
yeah its taken a pretty good hit, the screen has a broken ink cartrige, and the touch pad for the mouse has probably come unpluged from the mother board
eMachines... | Answered on Dec 30, 2014
you could try driverguide.com
eMachines... | Answered on Dec 04, 2013
u have to open back cover and replace battery
eMachines... | Answered on Nov 08, 2013
YES YOU NEED TO RE INSTALL WINDOWS..TEKGODS.COM
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
eMachines... | Answered on Oct 26, 2013
1) In some cases, you can buy the recovery media from the manufacturer.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
(needs your serial number and often is restricted to purchase during the initial warranty period)
2) Your computer came with a Recovery Management tool which would have allowed you to burn your own. (Too late for this to work)
3) In the Bios see if Disc to Disc Recovery (D2D Recovery) is enabled (Press <F2> during the POST to enter the BIOS.) It will be in the Main section. If it is enabled (or after enabling it - save and exit the BIOS), restart the computer and press <alt> and <F10> simultaneously when the eMachines logo is visible. You should enter the Recovery section and follow the directions. Please note this will reformat your hard drive and you will lose any data that wasn't previously backed up.
I sometimes find it hard to time these startup key strokes, try again until successful.
I hope this helps.
(The D2D recovery information is in a hidden partition (15 GB) on the hard disc, if your computer had the feature. Backing up your data and checking if the hard drive has this partition can be done with a LiveCD of either a UNIX or some other system utility programs (if you have a second RW optical disc or an external hard drive). Using a LiveCD requires hitting <F12> at the eMachines logo to enter the boot menu.)
eMachines... | Answered on Aug 19, 2013
go to e machine website and download camera driver
eMachines... | Answered on Jan 26, 2013
XP, Vista, and Win 7 32bit OS's are limited to 4GB, regardless of any hardware limitations.
eMachines... | Answered on Sep 27, 2012
Yes this is possible. You will need to bridge connections between your WIFI adaptor and Ethernet ports.
Navigate to Network connections, select both your WIFI adaptor and Ethernet adaptor. Now right click and select "bridge connections"
Take care!
damnor01
eMachines... | Answered on Sep 12, 2012
No need to re-install.
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you reset windows password soon.
eMachines... | Answered on Jul 26, 2012
Try (on the bottom of the laptop) removing the door to the RAM, and pulling one stick out at a time, than starting it, and than the other stick, and starting it. If you still have a black screen, than the motherboard has gone.
eMachines... | Answered on Jul 21, 2012
Looks like you will have to reinstall windows, unless you have a recovery disc.
If you have the original Windows disc you can reinstall windows.
If you want to keep all your old vids and pics, just put the disc in the drive , then restart your pc, make sure its set to boot from disc drive.
install windows on the same place it is now DONT format the drive if you want to keep stuff, if not format it. if you dont format it will put all your current files into a folder called Windows.old after you get a fress install go to C: and look for windows.old
eMachines... | Answered on Jul 12, 2012
Try to boot to "safe mode" by pressing F8 frequently after switched on, choose safe mode. If it works then restart your pc. If it doesn't you can use OS CD to recover, choose start up repair.
eMachines... | Answered on Jun 08, 2012
Could be a simply focus adjustment within the cam software that needs to be done. Or the cam is bad itself try adjusting the focus wheel as well. It may be out of focus. Usually the adjustment is on the lens turn it in or out. Try testing the cam on another computer close by see if it is working well on another computer. If not replace the cam. Try re installing the cam software and driver files. John
eMachines... | Answered on Apr 20, 2012
Go to start menu, my computer,right click on C drive, click on properties, click on tools at the top, click on check now, this will run a full error test and you will have the option to fix bad sectors if possible
eMachines... | Answered on Mar 17, 2012
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
eMachines... | Answered on Feb 25, 2012
eMachines... | Answered on Feb 19, 2012
eMachines E620-5885 Notebook Logo
74 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
much ram install in e620 5885
  • Computers & Internet
