20 Most Recent Acer Aspire One Netbook Questions & Answers
2answers
Serial number for idm 6.18.1.2 inspiron mini
There should be a white tag somewhere on the back of your inspiron mini with the serial number on it. Ponder/Meditate/Pray for Peace. Mary Oliveau { hugs }
12/14/2018 3:45:40 PM • Acer Aspire One... • Answered on Dec 14, 2018
Shows a blue box and says Harddisk security.
not sure if this link will help you out but have a look.... Acer Hard Disk security Google Search
10/25/2017 2:41:23 PM • Acer Aspire One... • Answered on Oct 25, 2017
Conecting to verizon jetpack
I had them and others. They do not work well and are not worth the money. If you have cable with a wifi hotspot option, you would be better off using that.. The Jetpack sucks big time. Cancel the mifi service.
10/4/2017 12:54:22 PM • Acer Aspire One... • Answered on Oct 04, 2017
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
8/4/2017 4:02:42 PM • Acer Aspire One... • Answered on Aug 04, 2017
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community. If this helps, you can indicate as much - g'luck. http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
6/28/2017 3:04:00 PM • Acer Aspire One... • Answered on Jun 28, 2017
Hi there i have an acer aspire one d255e windows 7
if password or security code is accepted nothing to do with restore points or recovery will be the wi fi chip inside the laptop use the trouble shoot function or check the wi fi set up on the laptop either too far away from modem or house insulation or construction weakens the signal best solution is buy a long Ethernet cable
4/28/2017 1:11:10 PM • Acer Aspire One... • Answered on Apr 28, 2017
Acer Aspire One 0751h Crystal Eye webcam not
Make sure it isn't turned off in Bios by entering setup when you power it on (Usually <del> or F12)
3/24/2017 6:18:20 AM • Acer Aspire One... • Answered on Mar 24, 2017
2answers
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
1/3/2017 6:34:17 AM • Acer Aspire One... • Answered on Jan 03, 2017
4answers
I need to know how to get the administrative
Depending on the OS you can Ctrl + Alt + Delete and it would change to a screen that you can enter a user name and password.
Enter the username "Administrator" and leave the password blank or try "admin" or "administrator"
If your able to login with those details you can go to
Control Panel > Admin Tools > Computer Management > Local Users and groups (On the left) > Users > and then right click the username you forgot the password for and click "Set Password"
OR
Forgot Windows Password? Would you like to choose to reinstall the OS ? If not, then follow this tutorial to recover/remove the password.It is adjust to Windows XP/Vista/NT/2000/2003/2008/7.....
1.Download Windows Password Recovery utility from Password Recovery Official site :
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html
2.Decompress the Windows Password Recovery utility and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Windows Password Recovery utility
3.Insert the newly created CD into the locked computer and re-boot it from the CD drive. 4.After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
1/31/2016 4:30:00 PM • Acer Aspire One... • Answered on Jan 31, 2016
2answers
My samsung laptop wont turn on but has full charge
Hi there, No power or computer does not turn on I hope this can help you. :)
10/5/2015 6:12:05 PM • Acer Aspire One... • Answered on Oct 05, 2015
How to install and download goggle play on my laptop
Hi. Are you referring to install and run andriod application to your PC? if Yes, You need to install a Andriod Emulator example a Bluestack. Here is the Guide: How to Run Android Apps on Your PC or Mac
9/26/2015 12:03:22 AM • Acer Aspire One... • Answered on Sep 26, 2015
Power button stuck on acer aspire one netbook
try to open the panel if u r xperienced go to any repairing service center the will do it
9/11/2015 6:25:30 PM • Acer Aspire One... • Answered on Sep 11, 2015
2answers
Need to add memory to Aspire one
you will need to open the bottom of the laptop and you will see the ram in there.
4/6/2015 10:20:12 PM • Acer Aspire One... • Answered on Apr 06, 2015
Black screen of death on my acer aspire one
plug in a monitor using a usb and vga cable,if it works then it could be screen gone or what they call the inverter thats gone.
4/5/2015 9:13:32 PM • Acer Aspire One... • Answered on Apr 05, 2015
2answers
I have a used acer netbook that purchased i has no internal hdd and a very small size memory which i cant find it is a acer one 1745Fzg5
it takes a sata hard drive.it also needs an adapter to fit the end of the drive. used-acer-netbook-purchased-no-internal-rhk1zqt1samwchlmqu5ablrp-5-0.jpg used-acer-netbook-purchased-no-internal-rhk1zqt1samwchlmqu5ablrp-5-1.jpgthere are two type of adapter.that fit the sata drive .
12/14/2014 9:33:55 AM • Acer Aspire One... • Answered on Dec 14, 2014
My acer aspire one 725 keyboard not working
time to get a new keyboard.there about £10.00 on ebay and very easy to change.dont waste time trying to fix it.i have seen this problem many times with laptop keyboards.
11/29/2014 5:07:40 PM • Acer Aspire One... • Answered on Nov 29, 2014
Intenet exploer blocked security cetificate wont turn of
check to make shure that your date and time is correct.if it is not you will get security problems and internet page will not display.
11/29/2014 5:05:20 PM • Acer Aspire One... • Answered on Nov 29, 2014
I want to install windows xp on a windows 7 netbook acer
try scanning your hard drive for spyware and mailware.use malwarebytes its free to use and will remove problems.that might slow your computer down.also try upgrading your memory.if you have a celeron or amd cpu.that could be your problem as to why it is slow
11/29/2014 5:03:19 PM • Acer Aspire One... • Answered on Nov 29, 2014
326 questions posted
Steve Sweetleaf
Steve Sweetleaf
shadow
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
used acer netbook purchased no internal
  • Computers & Internet
