I would not advise raising the teeth any higher unless they have dropped down, with the teeth fully up crouch down so the teeth are in your eyeline and they should only be just above the plate, if you raise them up above what they should be you are in danger of breaking the needle plate and even the teeth holder which will be expensive
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
SOURCE: After tangle in thread and jamb, feed dogs do not
Have you moved the lever shown on page 12 or 13 in your manual? I looked at your manual at www.singerco.com and it showed a lever in the rear of your machine to move. If, you misplaced your manual, download one for free from the Singer site.
