One of these two sites might be able to help you:
http://www.videohelp.com/dvdhacks
or
http://dvdexploder.com/
SOURCE: Unlocking the LG HT303su DVD from region2 to region 0
Hi, I could not get it to work using the other ways, Also I am not sure if this might help I am in Australia region 4 and the below worked for me
(1) Make sure there's no disc in the system and turn it off. Turn the system on again and it will display a "no disc" message on your TV.
(2) Use the remote control: press the "PAUSE" button and then key in the code "314159"
(3) Your TV then displays a menu for choosing the desired region. Select "0" to make your unit an all region player.
(4) Press the "PAUSE" button again.
(5) Turn the system off and wait a few moments before restarting.
SOURCE: LG RH2T160 unlock all regions
press HOME
scroll to SETUP OPTIONS
scroll - down - to the LOCK icon
press SEVEN ZERO's - message appears
press ENTER.
also used after message; 'unknown disc; please check disc again'..
my indonesia built area 4 marked lg rh2t160 would
play most area 1 dvds, but not all, from new..
7 X 0 hack using remote = plays all discs..
SOURCE: Hi, I need to unlock
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
