Question about LG HT303SU Theater System
How to remove disc error message for my lg ht303su-a2 dvd cd player because it plays some dvds and other dvds wont play
HOW TO REMOVE DISC ERROR MESSAGE FOR MY LG DVD PLAYER
Posted by amos job on
Audio Service Clinic
  • LG Master
  • 924 Answers
Check a CD. If it plays, the Optical Pickup for the DVD is worn out and will need to be replaced.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Posted on Aug 10, 2015
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Posted on Sep 19, 2009
Anonymous
  • 267 Answers
SOURCE: LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
Anonymous
SOURCE: dvd/cd ejects any disc installed
I have exactly the same problem. Have you found a solution?
Posted on Jan 26, 2010
Anonymous
SOURCE: LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Posted on Jun 27, 2010
Anonymous
SOURCE: "Disc Error"
Try lens cleaner hope it will works.
Posted on Dec 30, 2010
HOW TO UNLOCK LG DVD HT303SU-A2 TO PLAY ALL REGIONS?
One of these two sites might be able to help you:
http://www.videohelp.com/dvdhacks
or
http://dvdexploder.com/
Oct 25, 2013 | Televison & Video
I cant get my lg ht303su system to play sound from my television how do i do this?
Connect the RCA cables ( red, white, yellow cables) to the necessary jacks o the DVD player and tv..the DVD player should have an "AUX" input amongst the other inputs eg DVD,USB etc..this allows you to play sound from the TV through the DVD HT
Jan 05, 2013 | LG HT303SU Theater System
Trouble playing DVDS
Try a good wet type cd dvd lens cleaner and you may need to upgrade the firmware check the LG website.
Good luck
Rich
Jun 06, 2010 | LG DR787T DVD Recorder
My dvd player plays cds but wont play dvds says disc error or unknown disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer. In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
Apr 21, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Apr 29, 2009 | LG LXD5230 System
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
LG HT303SU Theater System Logo
270 people viewed this question
Top LG Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
