The mainspring is not bad or the carriage would not move that way. It sounds like and escapement problem either from the carriage release sticking, the escapement itself needing adj. which you probably cannot do, the escapement rack is bent or maladjusted, or the tab function is sticking or maladjusted. Check the carriage release levers to see if they are sticking. Also make sure the tab function is knocking off so the carriage is not in constant tab mode. Hope this helps.
SOURCE: Olympia Startype 3 Typewriter
I need a manual for the olympia startype 3 typewriter. How do I optain that?
SOURCE: electric typewriter set the margin
if you still have problem, repost with make and model typewriter, different methods are used with different machines
SOURCE: Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
