SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
SOURCE: Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
SOURCE: zanussi aquacycle 1000 washing machine spin problem
My zanussi aquacycle 1110 sounds like it is about to take off when it goes onto a spin cycle. Does anyone know what it could be? The big black spings are still in place inside the washer that hold the drum. It also rattles more than normal as well. Thankyou
