Washing Machines Logo
Question about Electrolux Washing Machines
Zanussi electolux aquacycle 1200 w/mc wont spin
Zanussi electolux aquacycle 1200 washing machine spins but clothes still wet
Posted by janet_hazleh on
hcollins
    New Friend:
Try new bushes and make sure where bushes run is clean and free from carbon H
Posted on Mar 04, 2010
1helpful
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
6helpful
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
7helpful
My zanussi aquacycle 1200 is not spinning all the water out of the clothes during the wash. It is washing them ok but leaving them soaking.
Check the filter is not blocked.
This is located at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
3helpful
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
1helpful
No spin & drum is very noisy during cycle ,like a jet engine
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
1helpful
Will spin on empty, but not with load in.
  • this is like this we have to get a sattilite worker to put it under it to solve it
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
