SOURCE: my liebherr freezer has a icemaker. It barely
Check freezer temperature. Must be 12*F or lower for I/M to work properly.
SOURCE: Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To
cycle this ice maker, pull the front cover off of the ice maker. You
will now have access to the module which has some test terminals marked
on it (I'm sending you a picture). Using a well insulated jumper, place
it between T-H and the ice maker should start to cycle.
Be careful this
is a hot (live) check. If the ice maker starts, after about 5 seconds
remove the jumper. It will take a few minutes for it to break the ice
free and if it cycles completely and refills the ice maker will need to
be replaced. This indicates it's not starting on its own. If it just
stops on the ice, the mold heater may be open. You should be able to
feel the bottom of the ice maker to see if it's getting warm but be
careful, if you touch the mold heater, it can be very hot. If the mold
heater is not hot, again the ice maker will need to be replaced. If the
ice maker never cycles with the jumper, there may not be any voltage
getting to the ice maker. Some voltage checks will need to be made and a
technician will be needed to make these checks.
Hope this helps.
SOURCE: I have a liebherr refregirator
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
SOURCE: My Liebherr ign 2566 freezer
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped.
All the best
Elect_Comp
