I have an Olympus Stylus 1010 digital camera that I dropped recently. The small plastic battery door lock has snapped so that I can no longer lock the battery door. I have sourced somewhere where I can buy a replacement unit (the entire battery door), but I'm not sure how to remove and replace it. I only need to replace the sliding plastic lock, but can replace the whole door if necessary.
SOURCE: broken battery cover.
I have a broken battery cover on my Olympus Camedia C-370 zoom digital camera.
Would you let me know, where I can obtain a replacement. I live in SW France.
SOURCE: I have the date on
Normally many cameras do not have date printing in its feature ..... while there wud a date setting ..... still try in your menu if there is any time or date stamping feature that needs to be turned on
SOURCE: olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
http://www.digitalcamerapartsdepot.com/Olympus_Parts/VK127200.asp
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
SOURCE: Instructions for replacing Olympus Stylus 820 battery door
Give a call to 305-653-7355 they can help
Ask for Zack
SOURCE: How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Did it get wet?? Are you sure battery is charging? You can send it in to Olympus repair dept. for a free estimate. http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp Mine was still under warranty so everything was free and they had it back to me within the week. For a my sister's wedding. Unbelievable!!! Great experiance!
