SOURCE: 2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1)
your software is telling the printer the label length is longer then
the current labels, even if the label size is out my a single
millimeter the printer will give you this issue of feed an extra label.
you need to change this in your software. you can set a label size
smaller then the current label size and it will work correctly
2)
you software is not setting a label length and so the printer is going
off its internal setting, to recalibrate hold feed and power up the
printer letting go after the light starts flashing
it is
important to note that label roll will change slightly over time so
even though you are ordering the same labels as a year ago the
manufacturer will have slight changes from batch to batch
SOURCE: Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
