Question about Zebra LP 2844 Thermal Printer
2 LABELS COME OUT
EVERY TIME I PRINT A SHIPPING LABEL FROM MY LP2844
TWO LABELS COME OUT BEFORE THE MACHINE STOPS.
IT PRINTS ONLY ON THE 1ST LABEL.
BUT THEN I HAVE TO GET UP AND REWIND THE LABELS BACK ONE
SO AS NOT TO LOSE THAT LABEL
I HAVE TRIED TO RESOLVE THIS IN ALMOST EVERY WAY I CAN THINK OF, FROM RECONFIGURING THE PRINTER TO TRYING DIFFERENT LABEL LAYOUTS
Posted by torrero on
  • livewire2 Nov 28, 2007
    I am having the same issue and have tried the listed solutions with no luck.
  • Anonymous Apr 01, 2014
    printer prints multiple shipping labels for one order on amazon website
Anonymous
  • 53 Answers
Your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Posted on Nov 09, 2007
Zebra LP2844 pulls labels in before printing
Yes, first of all, it is necessary that the labels are pulled backward (other wise you could not print on the upper part of the label). It appears from time to time that it is a problem - generated by the label itself. Try to use a different label (of size and material) to see if the behavior changes ...
Good luck.
Apr 16, 2013 | Zebra LP 2844 Thermal Label Printer
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
Zebra Eltron 2844 is not printing 4x6 shipping labels. I am using the printer to print FedEx labels. i recently had to reinstall the driver, and now when I print, it prints just under 2x4, rather than the...
You can recalibrate it to read the label size by doing the following.
Power off the printer
Hold down the green button
Turn the printer on and about 1/2 second after turning it on, release the green button
It will print out some information and measure the label. Once it stops, hit the green button one last time and then try to print another label.
Jan 26, 2011 | Office Equipment & Supplies
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 thermal printer
open the unit and on the front top you will see a thermal print head, (looks like a shiney bar) using an alcohol based solution clean the head, you prints should be much clearer now.
xbm
Nov 07, 2008 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 Thermal Printer Logo
663 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
