Have you thought about going online and buying the printer cartridges from an Ecommerce store there are plenty of them around and one is bound to have the cartridges you need.
Hi
Unfortunately there is no way to set your printer to use zone 2 cartridges or to change the zone as in Brazil which uses inkjet cartridges zone 02 compared to Sweden(which uses inkjet cartriges zone 363) .HP recommends that you use genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help you easily produce great results,time after time. Please check this manual for further information on ink cartridges:
HP PHOTOSMART D7360
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Hi
I understand your situation however this is the only solution to the problem and unfortunately there is no way to set your printer to use zone 2 catridges or to change the zone. If you want you can always contact HP and they will tell you the same thing.
Thanks
Rylee
Your HP printer can be made region free(so that you would be able to use zone 2 cartridges) by HP people only as the they will ask you for the cartridge serial number and will tell you how to make those cartridges compatible with the Printer. HP people will go 'calculate' and then will provide you with 5 four digit numbers which you'll need to enter in Control Panel -->Printers(They'll tell you the exact procedure and those serial keys tomake your printer zone free). You can chat with them online by clicking on the link---
HP LIVE CHAT
I believe the only solution is to use HP Support and to also write an email complaining about how weird this process is. HP started this zone cartridge criteria after it was seeing loss in revenue as people were buying cartridges that are cheaper in parts of the world and shipping them and padding their profits.
Thanks
Rylee
Hi, thanks for the answer, but it doesn't help me at all, first of all, because I bought a genuine original HP cartridge, the "only" problem is that now living in Brazil, I simply cannot buy HP cartridges from here.
If there is no other solution for this problem, unfortunately I must say I'm not satisfied with the service and I would like my money back.
Kind regards,
Have you thought about going online and getting the printer cartridges from an Ecommerce store? There are plenty of them around.
