I have a kodak easyshare printer dock series 3 .it prints half of a picture.it is ok along the length but prints only the left side of the width.you could also consider it the top half of the print as with people you get the bottom half of the print. any help would be appreciated. bob sheehan
Standby i'll sent you how , for a while
Friend. The first thing to do is go to the printer settings then the maintenance utility.
1. perform the head cleaning
2. perform the nozzle check.
3.if it still appears the prblem
4. remove all the ink and shake it for few times then install it once again.
5.perform the testing print.
6. last try to reinstall your printer software driver.
But if the problem still occurs try to read the solutions below and perfrom it
Understanding Potential Problems
Printers are mechanical devices with lots of moving parts. And any time you have moving parts, you have something that can break or wear out over time.
So when you click the old print button and nothing happens, what are the likely causes?
First, you might have the wrong printer driver installed in Windows. You might have either simply selected the wrong driver for your printer, or Windows might have mistaken your printer for another model, or the driver selected might be out of date. While we're in this area, it's also possible that various aspects of your printer setup might be incorrect, which can cause some highly unusual problems. You should also check your font setup because fonts themselves can cause perplexing problems if they're not installed correctly.
In addition, any new input or output device you've installed since you installed your main printer could have changed your printer's settings. (It's kind of like the last device installed gets dibs on key system settings.) If you've recently added a scanner or a digital camera or fax software or anything like that and then experienced printer problems, try uninstalling your printer (and all printer drivers) and then reinstalling your printer so that your printer is now the last device installed—and thus controls key system settings.
It's also possible that if you're printing large or graphically complex documents, you might not have enough disk space or memory to print. Make sure that you have plenty of both, because Windows needs all the space it can get to complete the printing operation.
Finally, you could have real printer hardware problems. These problems range from the mundane (you're out of paper, you forgot to turn on the printer, a cable came loose) to the fairly serious (your printer is broken!). Check all your cables and connections and make sure that your printer is actually turned on.
Problem: Your Printer Prints, but Output Is Smudged or Garbled
If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
Problem: Your Printed Page Looks Half-Finished
If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
or You may visit this site: http://computerchimp.com
hope i helped you good luck. just sent me for follow up questions
Go to your printer property in control panel set A4 size paper .
