20 Most Recent Kodak EASYSHARE Printer Dock Thermal Photo Questions & Answers
SOLVED!!
eppelr is correct, the small white cam on the right hand side at the top (internally) cracks and this allows it to come loose on its shaft and stops it from pressing the thermal head down onto the ink film on one side. If like me you have the top of the range bluetooth model its worth buying an old basic model off ebay for a tenner and robbing the shaft out of that. The mechanics are more or less the same and the shaft itself is identical, Doubt you would be able to buy the shaft seperate from Kodak, Thanks eppelr, I now have two working plus 3's.
If anyone wants pics etc please get in touch
Kodak EASYSHARE... | Answered on Apr 08, 2012
hello, one of the cams that push printhead down is broken, this can be fixed, i have used strong wire with super glue to lock in place, but its a bear to do, since timing can be thrown off. so it might be cheaper to replace. sorry.
Kodak EASYSHARE... | Answered on Oct 11, 2010
You may have to download that printer. Merely swapping out similar printers is not enough Please post your feedback and Vote if the problem resolved as per your satisfaction.
Kodak EASYSHARE... | Answered on Jul 12, 2010
sounds like you have too much paper in the tray, take some out. 2nd, make sure no paper particles are jamming the rollers. hope this helps.
Kodak EASYSHARE... | Answered on Apr 29, 2010
Low ink Lable,reffil cartages
Kodak EASYSHARE... | Answered on Apr 18, 2010
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Kodak EASYSHARE... | Answered on Apr 12, 2010
switch off printer and on it . wait for 3 min and remove ribbon first and remove paper
Kodak EASYSHARE... | Answered on Apr 01, 2010
how to operate hp canon mf8180c. please tell the all functions in detail. how to refill, how to replace cartridge all these things. please tell me fast.
Kodak EASYSHARE... | Answered on Dec 27, 2009
SOLVED!!
Kodak EASYSHARE... | Answered on Sep 05, 2009
If this is the usual 'only prints half of picture' problem then..
SOLVED!!
Kodak EASYSHARE Printer Dock Thermal Photo Logo
59 questions posted
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
paper not feed
  • Office Equipment & Supplies
