If you need parts or repair for new models contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read the below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not
being manufactured anymore because of health concerns. New model use a
completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer,
if parts are not available, then the purifier was among the ones
related to health concer. In that case I suggest replacing the ionic
purifier with a different air purifier.
Note:On this particular problem: It is caused by arching, that was a factory defect. It is repaired replacing the plate. Since this is an old model, I suggest not repairing the unit.
I
have the same problem and haven't been able to fix it.However, others have had the same problem and
have posted their solutions.The
sizzling sound is caused by electrical arching between the plates and one or
both of the two tungsten wires that are run parallel to the plates (if you turn
off all the lights and wait for your eyes to adjust to the dark before turning
on the Ionic Breeze, it's a pretty cool light show!)Here are things found by others to cause the
arching and what they did to fix the problem:
--dirt, lint, or tiny hairs
stuck somewhere (usually towards the top or bottom of the plates or wire,
and maybe in the grid contact points).Clean it better.Using
canned air can help blow out the problem.
--water droplets.Make certain there is no moisture
anywhere when you put the grid (plates) back in.Using canned air can help dry hard to
reach areas.
--burn marks or melted
plastic.These indicates a short
circuit.Says dnewcombe1: "There is a
feeler bracket that guides the two rear thin wires while the cartridge is
being inserted. This "feeler" can melt and become disarranged."You can't fix this issue.
--build up on the ionizing
wires.Clean them.It's hard.I took mine apart and used steel wool.
The internal high-voltage grid wires are connected to a switch which is maintained in the closed position by the tension on the wire.
This red light comes on when the tension in the high-voltage grid wires relaxes or one of the wires breaks thus opening the switch.
There is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended.
Like you I went through the hard-core cleaning pocess, but found it usually makes no difference or very little.
You could try E-Bay for a replacement or shop for a more rugged ozone-generating air purifier -- I'm looking for one myself.
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
Replacement grids have been posted to ebay. You can replace the complete unit for $45 on ebay so that would probably be a better solution. The last grid I purchased on ebay for similar was around $20.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Ionic breeze gp s1730
I had the same issue. There are two switches in this unit. One closes if the back cover is on, the other closes when the removeable grid is in. My problem was with the later. Mine had corroded wire ends where it is soldered to the small circuit board where the switch is attached to. It also had a bad switch that did not close the circuit and I suspect internal corrosion as well.
Unplug the unit and remove the grid.
Remove the 4 small phillps screws from the front grill, remove front grill.
Remove 2 selector whells from top, remove four screws.
