Question about Sharper Image Professional Plus Ionic Breeze GP (SI871) Air Purifier
Ionic breeze gp s1730
No power.
Plugged in to known good outlet.
No panel lights, no "blue" light
Is there an internal fuse?
Any help would be appreciated.
Thanks
Dean
Posted by dyam on
  • TomTate Jan 28, 2008
    I have the same problem...no lights...no nothing when plugged into a know good outlet...I have even swapped out two new bulbs and nothing...
  • wfish Mar 22, 2008
    fell over and now no power. Can't find the fuse. Is there one? And if so, where is it located? The grills are on fine.
Anonymous
Ionic breeze gp s1730 I had the same issue. There are two switches in this unit. One closes if the back cover is on, the other closes when the removeable grid is in. My problem was with the later. Mine had corroded wire ends where it is soldered to the small circuit board where the switch is attached to. It also had a bad switch that did not close the circuit and I suspect internal corrosion as well.
Unplug the unit and remove the grid.
Remove the 4 small phillps screws from the front grill, remove front grill.
Remove 2 selector whells from top, remove four screws.
Test the switch function with ohm meter
Posted on Jan 19, 2008
martinmarty
    Scholar:
  • 62 Answers
This goes along with ted-qcom's solution posted Jan. 19, 2008. My Ionic Breeze GP had the same problem. It was the switch in the front that detects when the collector grid is in place.
I found a suitable replacement switch at Mouser Electronics, mouser.com. It is Mouser part # 101-1203-EV. The problem is that the lever is too long, so I cut it with my Dremel cutting wheel before installing.
Mouser also has a similar switch, part # 101-1201-EV on which the lever is the correct length, however it has solder lugs instead of PC board legs.
I ordered both switches and then made my decision about which to use after looking at them. The choices are either cut (shorten) the lever on the 1203 switch or enlarge the holes on the mounting board to fit the 1201 switch. In my judgement it was easier to cut the lever.
The new switch is installed and the unit is working fine again.
$1.24 + shipping for the switch.
Posted on Aug 10, 2008
Anonymous
Dean,
I have a Ionic Breeze GP Professional that did the same thing. I bought two of them that were factory serviced. One of them did that and I completely took it appart and cleaned it out like new. I even unscrewed the bottom and looked for a fuse. I did not want to break the casing so I couldn't tell. But once I put it back together and plugged it in, it worked fine. I do have a problem with the other one though. It doesn't work and the cleaning overdue light wont go out. I hope you have good luck with yours.
Jerry
Posted on Feb 16, 2008
Anonymous
Make sure the front and back panels are snapped into place.
Posted on Jan 22, 2008
Anonymous
Same question:
- No power
- Plugged in to known good outlet.
- No panel lights, no "blue" light
- Is there an internal fuse?
Thanks!
Phil
Posted on Dec 20, 2007
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
S1730 sharper image ionic breeze GP
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
Dec 02, 2007 | Sharper Image Professional Plus Ionic...
I have a Sharper Image Ionic Breeze GP S1730 the inside wire broke on. Does anyone know how to repair it????
One person used piano wire, but the diameter must be right so the cleaning beads can slide up and down on the wire when the unit is turned up and down.
Oct 22, 2013 | Sharper Image Ionic Breeze GP SI730 Air...
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
May 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Purchase Ionic Breeze #S1730GBX
Here is a link....actually you will need to copy and paste...its all one link....Ebay
http://cgi.ebay.com/SHARPER-IMAGE-GP-IONIC-BREEZE-AIR-PURIFIER-S1730-EXCT!_W0QQitemZ290304206696QQcmdZViewItem
I hope this helps....good luck and thanks for rating my effort.....the Fang.
Mar 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze
Is this the same as a S1730?...if so...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Professional Plus  Ionic Breeze GP  (SI871) Air Purifier Logo
1,574 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
