Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
I don't have an owners manual and after a few days of getting the lumipure, a blue light started flashing on top. I'm guessing a filter needs cleaning or someting. I cleaned the blades and don't see any other servicable parts. help???
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Posted on Dec 15, 2009
The blue light means it is time for cleaning. Your unit should have come with a wand that has a spongy surface on the end. This is used to clean the "guts" of the air purifier. That means you have to push the little black button on the front and open the top. Pull up and out the unit that is held together with a plastic nut. Unscrew that nut and the unit comes apart. Clean the outside of each piece with a wet rag and the inside with the cleaning wand. Let it dry and then put it back in the unit and start if back up. Don't forget, you have press the start button twice to make the purifying (ultraviolet) light come back on.
The blue light flashing means it's time to clean. When you put the clean filters back in then yes, hold it down for five seconds or so to reset the light. Pushing the on/off once turns the unit on, pushing twice turns on the uv-c light.
Posted on Aug 05, 2010
May 24, 2014 | AirFree Onix 3000 Air Purifier
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Feb 03, 2011 | Ecoquest Fresh Air Air Purifier
May 01, 2010 | Oreck Super Air 7 Air Purifier
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
Jul 19, 2009 | Air Purifiers
Nov 23, 2008 | Air Purifiers
4,375 people viewed this question
