F15 error on display and not drying clothes but still some heat. Checked thermostats with test meter and they look ok. Is this a relay module fault and is their anyway of testing it ? This fault is intermittent which suggests this could be sticking relay ?
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Check all thermostats , check to be sure you have 220 volts coming into the machine. Use ohm meter & check from heater element to the heater case or cabinet to see if the element is grounded. Positive to element & Negative to case should show no ohms if it does it is shorted. Also heater circuit runs through a centrifical switch on the motor
so if the motor quits the heater shuts down so you don't have a fire. When the motor is not running the fan stops.
You could check this switch but it don't happen very often. check this switch last. Hope this will help you
the model number that comes up is DLL2650BPL you could have a bad igniter,gas coils or sensor but the only way to tell is by reading them out with a meter the igniter part number is WE4X444 gas coils are part 5303931775 and the sensor is part WE4X448 you can go here to see parts https://www.repairclinic.com/Shop-For-Parts/a8b95d49280/Model-DLL2650BPL-Hotpoint-Dryer-Parts
if you have heat at the beginning and then no heat it will be the gas coils but one of the coils still could be bad and not work at all but check all parts with meter before you start ordering parts you don't want to change out good parts.
You will find the heater and stats located behind the removable panel at rear of dryer, you will need a meter to test them for continuity. there are other possibilities for it not to heat, so do not assume it is a faulty heater.
Plz rate my solution.
Thankyou.
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Thnks.
You need to check the heater element and thermostats which are lolcated behhind a removeable panel at the rear of the dryer..
You will need a meter to do this. Remove one wire from each thermostat and with the meter on the ohms range, test for continuity,if the stats are o/k you will get full scale deflection on the meter., if no movement then stat faulty, you must replace both stats at the same time.
take note which stat goes where as it is important you get them the right way round.
If stats o/k then the heater element is probably faulty.Plz rate my solution.
Thanks.
PS, make sure all filters and vents are clean
Particularly the filter at the bottom left, remove it and wash it out under running water.
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores.
