Question about Hotpoint Dryers
No heat, clothes do not dry
Hotpoint Heavy Duty Clothes Dryer with Automatic Dry Control. Gas
Model #DLL26508P----- Last few letters/numbers unreadable. No longer provides heat. Drum rotates properly. On/off knob works properly. Appears to be working but clothes do not dry. Cool air circulates, no heat.
Posted by junedr on
Sal De
  • Hotpoint Master
  • 2,699 Answers
The model number that comes up is DLL2650BPL you could have a bad igniter,gas coils or sensor but the only way to tell is by reading them out with a meter the igniter part number is WE4X444 gas coils are part 5303931775 and the sensor is part WE4X448 you can go here to see parts
https://www.repairclinic.com/Shop-For-Parts/a8b95d49280/Model-DLL2650BPL-Hotpoint-Dryer-Parts
if you have heat at the beginning and then no heat it will be the gas coils but one of the coils still could be bad and not work at all but check all parts with meter before you start ordering parts you don't want to change out good parts.
Posted on Feb 09, 2018
5 Related Answers
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
Anonymous
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
Anonymous
SOURCE: heater doesn't work in Henmore air dry ( heavy duty 70 series)
dryer turns on but will not dry what can i check to see wats wrong with it
Posted on Feb 13, 2009
Anonymous
  • 93 Answers
SOURCE: my frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Posted on Mar 15, 2009
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
I have a GAS Speed Queen clothes dryer. I can't locate the model number. It says "Heavy Duty, Multi Cycle, All Fabric Automatic Dryer". I bought it new in September 1972. It has always...
It could be the vent chambers in the bottom of the machine from the front filter to the vent output to the rear exit vent ducting tubes....or the ducting itself. Flexable ducting, if you are using it, are well known to glog due to the multiple ringed wires inside. Flex is not recommended.
Also the gas line should be replaced with a gas flex line....it's the law here in CA.
Jun 26, 2011 | Speed Queen ADG4BR Dryer
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
My frigidare heavy duty crown series not heating
Mar 15, 2009 | Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Dryers Logo
95 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
