Kenmore 41392 / 41394 / 41399 Electric Double Oven Logo
A
Anonymous Posted on Jun 04, 2013
F01 Code F01 keeps on flashing, what does this mean? How to make my oven function again? Reset?
1 Related Answer
Anonymous
  • Posted on Nov 13, 2008
SOURCE: F01 code on the oven
we have the same problem
What does E1 mean
E1 flashing means that the product's firmware/software needs to be flashed or repaired again in order to function properly, this generally occurs due to inadequate voltage supply or sudden power failure of the Oven.
Mar 19, 2015 • Ovens
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Oven is displaying F01 complaint. I have no manual to see what this means.
Hello & Welcome to FixYa
F01 error in your whirlpool double oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2011 • Ovens
1helpful
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 • GE Ovens
3helpful
3answers
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
