SOURCE: Hoover vacuum handle attaching screws
They are just a coarse thread(very coarse) about 3/4 in long, phillips head.
SOURCE: can't get bottom plate off hoover model
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
SOURCE: How do I replace the belt on my hoover wide path fold away vacuum
on this model there will also be 2 more screws at the top near the back on each side. the hood will come off. there will also be a cover over the roller, remove this with 3 screws, this will expose the area of the belt.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: hoover elite, model no. u4671-930
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
