Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is leaking from bottom of cleaner
This is a great cleaner , but all of a sudden it pumped water tank dry , but constantly leaking water from bottom also. Don't know what to do
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Jun 20, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
912870
Points
7895
You may just have a split pipe from the water tank and thats why its leaking water out
Kimberly Hazen
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 13, 2014
Kimberly Hazen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25368
Points
I saw wear a couple of folks said to leave a 1/4" gap for the filter from the top of the lid of the dirt compartment . Well I didn't we those recommendations until 3 weeks after I had torn the steam vac all apart. I took the steam vac apart I don't know how many times but failed to look at the filter. After seeing those recommendations I check the filter. There was a gap. But that WAS the problem. I pushed it all of the way up and the leaking stopped AND my upholstery tool started working again. So I did the opposite to what everyone else said and it worked. FINALLY! So I recommend to check the filter, and make sure it's pushed up ALL of the way!
Robert Bryan
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 29, 2014
Robert Bryan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25416
Points
Mine had the same problem. The issue was the water pump assembly in the base of the unit. The pump assembly is made of very cheap abs plastic and is held together by clips. Mine was leaking all along one side of the assembly. Good news is that you can order and replace the part yourself. I used vacpartswarehouse.com
  • jon conners
    jon conners Mar 12, 2015
    Hey what does the water pump assembly look like and what's the part number?
  • jon conners
Hoover Power Scrub Elite. It's leaking out the bottom. Help.
Question edited for clarity.
It appears to be a known issue
Has anyone had water leak out the back? It's coming from ...
https://www.amazon.com > ask > questions
My Hoover leaks water and detergent. The leak is coming from the knob/spring. Poor design. It's been leaking almost from day 1.
SOLVED: Hoover spin scrub 50 leaking from bottom - Fixya
https://www.fixya.com > support > t17601159-hoover_...
Sep 2, 2019 - It's a water pump issue where the posts for the screws break causing a gap in the water pump assembly which then causes the leak. Go to the video Judith linked ...
1 answer · 2 votes: Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was ...
Hoover powerscrub 50 leaking water from underside ...
1 answer
Sep 6, 2019
Water is leaking from bottom of cleaner - Hoover ...
1 answer
Nov 14, 2019
Questions & Answers for: hoover carpet cleaner ...
Nov 15, 2019
My hoover spinscrub 50 leaks when i put the water ...
1 answer
Feb 23, 2017
More results from www.fixya.com
Hoover SpinScrub is leaking water. How can I stop it?
https://www.justanswer.com > General Questions
Sep 1, 2011 - Most often, it flows out of the bottom of the machine where the hose attachment nipple is located. The back of that nipple breaks and the nipple ...
1 answer · Top answer: Vacman : the foloowing is a reprint from a person who earlier had the same problem Vacman ...
Hoover Power Scrub FH50150 Troubleshooting - iFixit
https://www.ifixit.com > Wiki > Hoover_Power_Scrub_...
Have the device be off and remove the dirty water tank straight out using the bottom hatch and handle. Follow up with placing the tank back on, making sure that ...
Low Suction · ‎Hose Nozzle not Spraying · ‎Clean Water Won't Dispense
2answers
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
1helpful
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
2answers
Bissell proheat carpet cleaner leaking
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
retgf
Leaking Hoover Scrub Spin Carpet Cleaner
A picture would be nice. Be advised that broken plastic is hard to repair.
2answers
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Bissell water not working
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
