Hi there! If your side by side refrigerator unit is not cooling properly there could be several causes. The damper door, between the two doors, is not functioning properly and not allowing the freezer's cool air to move into the refrigerator's side to cool everything down. You also could have a clogged sealed system line or faulty compressor. Do you hear the unit running as normal? Do you notice any side of the unit, or external area, that is severely warm/hot to touch? Make sure the unit is clear of debris underneath and around any coils or connections outside of the unit. You may want to power cycle the unit by unplugging it or turning the circuit breaker off to it for a few moments. If these steps do not prove to be successful, please contact a professional for further assistance.
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
cooling.-------
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
