I know it means unbalnced load, the machine can slowly spin to drop the washing load from the top, to rectify the balance problem, but it can do this for hours !! Is this a main board or sensor problem, how do i check, any reset functions on these machines ? That would be a great start !
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
SOURCE: Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
SOURCE: L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
