Question about LG WM1814CW Front Load Washer
Error code UE on LG Front Loading Washing Maching
Just started this week. Repeatedly getting UE regardless of load size at 10 minutes left. Washer is trying to rebalance the load itself, but can't and will never complete the spin cycle. I am sick of dealing with sopping wet clothes. Have owned the washer for three years with no problem so far and all of the sudden this. Help, please!
Posted by solavino on
NOEL
    Top Expert:
  • LG Master
  • 8,546 Answers
This is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Posted on Oct 27, 2017
5 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Posted on Jul 05, 2009
Anonymous
  • 706 Answers
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Posted on Feb 22, 2009
steelskyway
  • 22 Answers
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
Cameron Scott
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
Can I do a software update to try and fix UE code on my top load washer LG WT4870CW myself?
Check to be sure the machine is level and that all four feet are touching the floor. Tighten the locking nuts on the feet to lock them into place. If that doesn't seem to be the problem, either the suspension rods or shock absorbers may be broken or worn out.
Jun 28, 2017 | LG Washing Machines
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2011 | LG WM-2277HW Front Load Washer
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
Jul 20, 2011 | LG WM-1832C Front Load Washer
Getting a UE code on LG front load washer
Hello there
The UE ERROR CODE
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board Normally this turns out to be the unbalance switch that has failed and needs to be replaced so i would have this checked first.
If you have a warranty on this machine still you should be able to use it ok?
Hope this is very helpful or you.
Best regards Mike
Sep 26, 2010 | Washing Machines
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
My LG 2077 stops counting down at 10 minutes and stays there and then shuts off and says UE on every load. Can I replace the timer or is it another issue?
This washing machine is very sensitive to medium to large loads. Try doing a smaller load to see if the error code pops up. UE stans for unmalanced load. Good luck!
Aug 21, 2010 | LG WM-2077C Front Load Washer
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
May 20, 2010 | LG Washing Machines
LG WM1814CW Front Load Washer Logo
578 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
