Frigidaire FRS26RLECS Side by Side Refrigerator Logo
Dave Toms Posted on Sep 25, 2017
My icemaker on my frigidiare FRS26RLECS2 is not working.
It doesn't appear that water is going to the icemaker from the bottom back valave but don't know how to check? Can someone provide trouble shooting steps to detect probelm. I am getting water out of the water dispencer. When I push the ice lever I do not hear any sound and there is no water or ice in icemaker. The bar is in the up position
5 Related Answers
Anonymous
  • 183 Answers
  • Posted on Aug 23, 2007
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Anonymous
  • 90 Answers
  • Posted on Jan 08, 2008
SOURCE: Frigidaire not making any ice...
check inlet tube behind icemaker and make sure its not froze up. If so, it may just need to be thawed out but if it happens again you will need to replace water valve.
Anonymous
  • 958 Answers
  • Posted on Oct 14, 2008
SOURCE: sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
gtaplytmpt
Andy
  • 90 Answers
  • Posted on Jan 02, 2009
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
ZZZoom
  • 151 Answers
  • Posted on May 14, 2009
SOURCE: Ice Maker just stop making Ice. The water still
Check the bar that's used to sense when the tray is full, is in down position.
Frigidiare frs26rlecs2 icemaker not working
Yes sounds like solenoid in valve for ice maker is not opening. Either the valve is bad or ice maker isn't sending voltage to valve.
2helpful
Icemaker doesn't work
If the ice maker is not filling, you will need to replace the "water inlet valve" on the back of the unit. Here is the part you need to order.
1helpful
The icemaker on my older kenmore side by side refrigerator doesn't make ice?
What you are probably dealing with is the little valve called (Water Valve) on the back of side of the refrigerator usually down low towards the bottom right hand side if you are facing the back of unit. Its the part that the water line run into and also will be a water line coming out of it going up the back of the fridge and goes thru into the freezer to the Ice maker in the freezer
2answers
No water going in
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
My LG ICEMAKER WORKS OFF & ON THE LIGHT & WATER WORK ALL THE TIME IT IS MODEL # LFX21971ST/02 THE ACTUAL ICEMAKING WORKS FINE, THE DISPENSER PART OF THE ICEMAKER IS THE PROBLEM, THE DOOR OPENS BUT...
NOTE: This
Leo Ponder
imufo2
1helpful
GE profile performance fridge, model TPS24BPCE BS..... water dispenser not working. Ice ok. Water coming into it from main line, but doesn't appear to be getting into filter (replaced filter). Any...
NOTE: This
Leo Ponder
imufo2
3helpful
RF201ADUX Fisher & Paykel ice maker doesn't make ice although we get water through the dispenser. It sounds like it recycles at times but no cubes. Any ideas?
NOTE: This
Leo Ponder
imufo2
First icemaker stopped making ice. repairman replaced whole icemaker. Still didn't work. now whole frig doesn't work. Motor is on but no cold air to both sides
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Ice maker not making ice. control box making faint buzzing sound. water supply ok. all appears to be assembled correctly & in operating positions
NOTE: This
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
The ice maker doesn't work & water drips down from the freezer to underneath the vegetable crispers. It is not the plug. Is there a turn off valve on the ice maker line so that no more water can...
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
