thanx for ur help but it didnt work..it seems that option doesnt appear on my 'Set' options, there is one that also is in black, hari86,
You can't post conmments that contain an email address.
Re: the radio and cd player work but cannot display...
Hi..make sure that u have turned on the
display button the set.once u have turned
off the display button in your set ur display
doesn't appear.This display option will be
available in the set.
check it out.
thank u.. rate me..
JustAnswerhttps://www.justanswer.com > chrysler > anxib-chrysle...
Sep 8, 2017 - This sounds like the display board in the radio has failed. But try rebooting the radio first by disconnecting the negative battery cable (in ... 1 answer · Top answer: Hello, my name is ***** ***** I will assist you today. This sounds like the display board ...
YourMechanichttps://www.yourmechanic.com > Questions
Jan 25, 2017 - I have a 2006 Chrysler 300 limited edition, and the screen went black on my rec nav. I can only change preset stations, eject CDs, adjust volume ... 1 answer · 36 votes: Hello. The issue you are having with your radio is a common problem with Chr
If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
be looking at radio fuses replace if blown then recheck..does the radio work? if it does then micro switches in the radio casing were compromised when those cds were jammed in it..
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
hari86,
