Yale Y150/30/125/1 Combination PadLock Logo
A
Anonymous Posted on Feb 04, 2013
How to unlock a yale combination padlock - Yale Y150/30/125/1 Combination PadLock
Reset combination on abus 165/40 padlock
How do i reset the code on an ABUS 145 series combination padlock
  1. Using the existing code, unlock the padlock.
  2. Rotate the unlocked shackle 180 degrees and then press it down.
  3. While the unlocked shackle is depressed manipulate the code wheels to the desired code.
  4. Release the shackle and rotate back 180 degrees.
https://www.lsc.com.au/Products/Padlocks-Hasps-Chain/Padlocks-Accessories/Combination/ABUS-165-Series-Wheel-Combination/16540C.html
How to reset digital cannon gun safe combination?
Go to cannonsafe.com and find their help line unless they have online instructions available. Be ready with any serial numbers etc receipt of purchase, where you bought it. They may not readily hand over the info.
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
1helpful
How do I remove the cylinder from a Yale Y130/70/116/1 padlock so I can remove a broken off key.
You can't. Make sure the cylinder is in the upright position, and tap the lock on a bench face down (very hard) it may dislodge it enough to grab it with some tweezers.If no luck, throw it away.
I want to open my padlock
It is very difficult and for this task you need to follow the manual guide given in locksmith san francisco or if you live there then can hire the locksmith professional as well.
I bought a lock bow it has a yale combo lock, don't have combo, only numbers I found are V5908 on it, took back off and all parts fell out, need help trying to put back together and maybe get it working,...
Look sorry to say but you have created a mess. Now what you have to do is to visit the San Francisco Locksmith website and see the manual guide to fix it. The better option is to hire their services or contact with them to know about fixing this issue.
1helpful
How can i unlock the combination lock on my
If its a padlock your talking about a quick answer is try making a shim.
( http://www.instructables.com/id/Open-Any-Padlock/ )
a long answer is start at 1 and work your way up. lol
Top Yale Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
