Question about Yale Y150/30/125/1 Solid Brass Body Padlock with 3-Dial Resettable Combination, 1-3/16-Inch Wide
How to reset digital cannon gun safe combination?
Posted by sierra severson on
Timllfixit
  • 2,210 Answers
Go to cannonsafe.com and find their help line unless they have online instructions available. Be ready with any serial numbers etc receipt of purchase, where you bought it. They may not readily hand over the info.
Posted on Jul 03, 2014
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
Forgot combination to sentry so100
hi foustulia you need to use your kay to open the safe and reset your combination to a new one
Dec 09, 2010 | Safe International Digital Electronic Safe...
I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
Yale Y150/30/125/1 Solid Brass Body Padlock with 3-Dial Resettable Combination, 1-3/16-Inch Wide Logo
406 people viewed this question
Top Yale Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
