Question about Yale Y130/70/116/1 Marine Grade Stainless Steel Disc Lock with Rubber Bumper, 2-3/4-Inch Wide
How do I remove the cylinder from a Yale Y130/70/116/1 padlock so I can remove a broken off key.
Posted by Bruce Johnston on
rallye
    New Friend:
  • 23 Answers
You can't. Make sure the cylinder is in the upright position, and tap the lock on a bench face down (very hard) it may dislodge it enough to grab it with some tweezers.If no luck, throw it away.
Posted on Apr 30, 2014
Testimonial: "I managed to glue the other part of the key to the broken piece with a small drip of Araldite and waited for it to cure then carefully removed the whole key."
How do I fix a key stuck in a padlock?
Make sure the lock is locked. Some padlocks retain the key while unlocked. Some padlocks trap the key when unlocked. Be careful not to break the key off. Jiggle, push and pull. If already broken, you might need pliers or a broken key extractor to remove it. A thin piece of stiff wire can sometimes be used to hook a broken key.
Sep 05, 2014 | Locks & Locksmithing
How to reset digital cannon gun safe combination?
Go to cannonsafe.com and find their help line unless they have online instructions available. Be ready with any serial numbers etc receipt of purchase, where you bought it. They may not readily hand over the info.
Jul 03, 2014 | Yale Y150/30/125/1 Solid Brass Body...
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
How to open Y130 - Stainless Steel Padlock without ihe key
Your lock will need to be seen by a locksmith, who can hopefully pick it open for you, or possibly open it by impressioning. If not it will have to be drilled.
May 19, 2014 | Yale Y130/70/116/1 Marine Grade Stainless...
I want to open my padlock
It is very difficult and for this task you need to follow the manual guide given in locksmith san francisco or if you live there then can hire the locksmith professional as well.
Nov 02, 2013 | Yale Y150/40/130/1 Combination PadLock...
I bought a lock bow it has a yale combo lock, don't have combo, only numbers I found are V5908 on it, took back off and all parts fell out, need help trying to put back together and maybe get it working,...
Look sorry to say but you have created a mess. Now what you have to do is to visit the San Francisco Locksmith website and see the manual guide to fix it. The better option is to hire their services or contact with them to know about fixing this issue.
Oct 30, 2013 | Yale Y150/30/125/1 Combination PadLock
Forgotten my combination for Yale padlock Y150/30
All I ever do is start at 001and work my way to 999
Oct 29, 2012 | Yale Y150/30/125/1 Solid Brass Body...
Broken key inside ignition
Your two choices are #1 remove and replace the ignition cylinder or #2 remove the cylinder, disassemble it and remove the broken key piece and reinstall cylinder. If you cannot handle the job, have a mechanic do it since it's quite a complex task getting that cylinder out and an even harder task removing the broken key piece.
Mar 04, 2011 | Ford Windstar Cars & Trucks
How to remove ignition lock cylinder, broken key inside
If the key is broken off inside the cylinder and u still have the other half of the key u should be able to insert the remainder of the key to get the ignition to turn forward. You'll have to remove the covers surrounding the upper half of the steering column and you will see a small pin on the cylinder to push to remove the inner part with the broken key. the key has to be in the on position to remove the cylinder and just reverse the removal to put it back together.
Dec 18, 2010 | 2001 Hyundai Accent
Yale Y130/70/116/1 Marine Grade Stainless Steel Disc Lock with Rubber Bumper, 2-3/4-Inch Wide Logo
162 people viewed this question
Top Yale Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
