Question about Yale Y130/70/116/1 Marine Grade Stainless Steel Disc Lock with Rubber Bumper, 2-3/4-Inch Wide
How do you unlock a yale 150/30 after puttn the combination code
Unable to unlock after putting in the combination
Bruce Johnston
    New Friend:
Sorry, I don't know anything about them.
Posted on Jun 17, 2014
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Unable to unlock with the three-digit combination I set.
Most vehicles require 5-digit combinations.
May 07, 2015 | Cars & Trucks
Well when I got this safe I had it for not to long and my safe was stored at a friend's house while I was in between moves well my purse got stolen that had the combination in my wallet and now my safe has...
It is good that you have the keys. Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 25, 2015 | Home Security
My tablet froze it won't even let me put the password what can I do ?
Remove the battery.
Wait for 5 minutes.
Check your phone-sim and memory-sim is inserted correctly.
Replace the battery.
Try one of the following immediately after you turn on the power and while the power comes on...
  • Combination 1 - Volume Up + Camera button.
  • Combination 2 - Volume Down + Power button.
  • Combination 3 - Volume Up + Power button.
  • Combination 4 - Volume Up + Home + Power button.
  • Combination 5 - Volume Down + Volume Up + Power button.
  • Combination 6 - Home + Camera button.
  • Combination 7 - Home + Power button
Combination 2 has worked for me in the past, but it depends on your Tablet type and model.
Feb 24, 2015 | Samsung Galaxy S3
Iam unable to unlock my n72 lock code
if it is just a user lock code and not the network lock code, you could enter this combination to format and clear all codes and data on the set. while off with no sim, press *,3 and call button smalteneously and power up unit. hold for about 2 minutes and release. phone will be reset.
Sep 25, 2010 | Nokia Unlock N70 N71 N72 N90 6630 6680...
I'm unable to turn on my buit-in webcam on my hp laptop
Pl check whether camera is not locked with any fn combination.To unlock u will have to fn+fn key(the cam logo will we there on that key from F1 to F12)
Oct 12, 2009 | HP Pavilion dv9000z Notebook
Ipod nano, my volume is locked on a 4 digit no.unable to undo
PLUG IT INTO THE COMPUTER AND RESTORE FACTORY SETTINGS
Apr 10, 2009 | Apple iPod nano
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
My Brass Master Lock Combination Lock is refusing to unlock. A couple of the combo numbers seem to be "sunk in" a bit. I tried WD40 but still will not unlock and I need to open my gate. This lock...
You need to make sure you are putting the righ combination. Try to put it the opposite way also for example
3645 or 5436
How many numbers are in the combination?...if it is a 3 number system it should be easy.
Artgirl
Jul 18, 2008 | Master Lock 5400d: Portable Select Access...
Unable to unlock
Restore the iPod in iTunes and uncheck the sync box or boxes you normally check.   Eject the iPod and now you will have a unil just as if you took it out of the box for the first time.   So, set the language etc. and go to the combination page and enter your new lock code.   Now re-connect your iPod to iTunes and restore everything you want on it.   It should work.   Good luck.
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Yale Y130/70/116/1 Marine Grade Stainless Steel Disc Lock with Rubber Bumper, 2-3/4-Inch Wide Logo
661 people viewed this question
Top Yale Locks & Locksmithing Experts
john h
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
