Kindly follow this link will help you
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01082964&lang=en&prodSeriesId=372334
Thanks for the info but I have gone through all the steps up to clean the rollers '• Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup. Figure 10: The rollers • Allow the rollers to dry for 10 or 15 minutes. • Reattach the rear access door.• Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup. Figure 10: The rollers • Allow the rollers to dry for 10 or 15 minutes. • Reattach the rear access door.• Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup. Figure 10: The rollers • Allow the rollers to dry for 10 or 15 minutes. • Reattach the rear access door.• Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup. Figure 10: The rollers • Allow the rollers to dry for 10 or 15 minutes. • Reattach the rear access door.• Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup. Figure 10: The rollers • Allow the rollers to dry for 10 or 15 minutes. • Reattach the rear access door.' But I cannot rotate the roller !
SOURCE: HP LaserJet 1012 Printer prints ghost images
A new toner cartridge solved the problem entirely.
SOURCE: D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
SOURCE: Paper feeds into printer 1/2way, stops, check paper light flashes
Yes, there is a sensor on the right side of the carriage that points down at the paper, you use a Q-tip moist with water and wipe the underside of this sensor, you may need a couple since quite a bit of ink sprays onto this sensor.
