It was only in the water for a second.
Hi santhosam123
Chances are its toast, but it is worth a try...sometimes it works
If you ever find that you have to deal with a wet device, don\'t just abandon it.
Instead, try the following method to repair the water damage:
DO NOT TURN IT ON!
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to suck the water out.
DO NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Please take time to rate me.
Bud
