1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
SOURCE: NEC MT850
We cleaned the filter on the projector and it has never happened since. Assume that it was overheating due to lack of airflow.
SOURCE: my NEC MT850 projects with a pink picture you can
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
SOURCE: Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
