SOURCE: scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
SOURCE: scanner password
HI there try the following.
Hope this helps you
Thanks J
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
SOURCE: Kyocera 2550 Scans but how do I OCR?
You can find documentation form Kyocera Printers here, though it barely mentions anything about their OCR feature:
http://usa.kyoceramita.com/americas/jsp/Kyocera/home.jsp
The OCR feature is only an image quality setting, producing a more black and white high contrast image rather than a grey scale image.
I'm using our Kyoceras to email the images to a server where "send mail" processes the image and runs OCRopus, an open source Google funded OCR project, to read information from the scan.
I'm finding there are many Virtual ReScan solutions, like Kyocera's OCR feature, VRS software produces OCR optimized images, though I haven't found an open source VRS project.
SOURCE: Kyocera KM-2050 scanner
You normally enter this information using your web browser and typing in the IP address of the scanner.
Hope this helps.
