20 Most Recent Kyocera Mita KM-2550 All-In-One Laser Printer Questions & Answers
http://usa.kyoceradocumentsolutions.com/americas/jsp/Kyocera/resource_details.jsp?rid=14162
Kyocera Mita... • Answered on Feb 11, 2020
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.In order to reset this code: follow those stepson the panel press 1087 1087The screen will change to service modeon the panel again press 163now look at the screen and you will see Excute.Select Excute and press the Start key.The Machine will rebot or it will asks you to turn it off and on.After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit. I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera Mita... • Answered on Jan 10, 2019
turn off machine unplug network cable turn it back on if it works your print job is the cause delete t
Kyocera Mita... • Answered on Feb 06, 2018
chek drum conector
Kyocera Mita... • Answered on Dec 18, 2017
Clean the slit glass or open the glass and clean the mirrors from the dust. I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera Mita... • Answered on Jul 23, 2017
this - two- reasons 1- the corrona on the top of drum unit is very dirty or its connection point are dirty with toner . just clean it then replace it again .if that not help you ll need to chick the corrona board
Kyocera Mita... • Answered on Mar 16, 2017
Not enough info. Do you not have a cable? USB perhaps?
Kyocera Mita... • Answered on Sep 09, 2015
This code is a defective developer or main PCB. I would try changing the developer first being that it is significantly cheaper.
Kyocera Mita... • Answered on Feb 11, 2015
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Kyocera Mita... • Answered on Nov 21, 2014
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
Kyocera Mita... • Answered on May 16, 2014
Switch on your bonjour in the printer settings
Kyocera Mita... • Answered on Mar 13, 2014
install proper print drivers. Install the KX version 6 drivers
You need the proper print drivers. Download the drivers and update or re-install your drivers
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Kyocera Mita... • Answered on Mar 09, 2014
program 10871087 after you selct 906 reset
Kyocera Mita... • Answered on Jan 30, 2014
my dear bro you selct 2by2 doplex
Defective DP main PWB. Device damage of EEPROM. not so good fault this one - if you are an engineer prepare for the main PWB replacement and calibration that follow ( you could try as a last resort re-writing the firmware/ replacing the eeprom chip and re-writing) if you are a customer- suggest you upgrade your printer to something else as it will be the cheaper option. Sorry for the bad news
Kyocera Mita... • Answered on Jan 16, 2014
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
97 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
error code c7410
  • Office Equipment & Supplies
