Apple iPhone 3G Black  Smartphone Logo
Posted on Oct 22, 2012
Can i use assistive touch? - Apple iPhone 3G Black Smartphone
4s home button not working
If it still is under warranty, bring it back to get it fixed! Until then, you can use Assistive Touch to be able to use your phone without problems.
Assistive Touch can be found under Settings>General>Accessibility>Assistive Touch
I cant turn on the ringer-so I miss calls
Try going to settings, then choose sounds. Try adjusting your volume by sliding the volume bar left to right.
You can also go to general, choose accessibility, then scroll down to assistive touch. Turn on assistive touch. That will put a small icon on your iPhones touch screen. You can turn your volume on or off through this button, you can also adjust your volume up or down through this. Hope this helps!
2answers
My iphone 4 power button does not respond on pressing. Please advise me what needs to be done. Should i change replace the power button or is there any alternate method?
I don't know about replacing it but you can use Assistive Touch ( Settings/ General / Accessibility / Assistive Touch on ). If your iPhone is jailbroken , activator is the best.
Aug 11, 2013 • Cell Phones
1helpful
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Visual land v-touch should be charged for how many hours
the charge time on the unit for a full charge is 4-6 hours. This was indicated by the manual. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
2answers
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
MANUAL FOR P-TOUCH 80
Dear Sir,
I feel Happy to assist you.
Manual For P-Touch you can download below Download Link.I think it solves u r problem.
Download
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
