Need the default IP so I can see about changing my NAT from Strict so that my 360 will properly connect to xbox live
SOURCE: Ok this is my problem i have a time warner arris
The default username and password for most routers I have seen is admin and admin provided you have not changed it. All are lowercase letters.Also I suggest you use the WPA or WPA2+ encryption if its available. The WEP is easy to crack wirelessly and I had a gala time cracking my neighbor's router in less than 3 hours!
Testimonial: "thank you very much even tought the default doesn't work because it doesn't have a default gateaway it says 0.0.0.0"
