20 Most Recent NetGear WNR2000 Wireless Router Questions & Answers
2answers
I have internet access when I plug in the ethernet
I know it is very frustrating if these things do not work. I am sure that the router is not setup properly that is why it is not working. It says connected because you have a good connection from pc to the router. But the connection from your Netgear router to the modem is not working. There is a possible IP conflict between your modem and router. I suggest changing the IP address of your netgear router to 10.10.10.1 . To do this click the link below:
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
Note: This is the manual for your router. Go to LAN TCP/IP Setup Parameters to change the router's IP address.
10/1/2018 5:48:10 AM • NetGear WNR2000... • Answered on Oct 01, 2018
I want to connect my Ipad 2 to my WiFi network. In
Hit the reset button(pin hole) on ur router and start all over setting up the router. Tape your new name and password on bottom of router so I don't forget
2/17/2018 6:24:14 AM • NetGear WNR2000... • Answered on Feb 17, 2018
NETGEAR WNR2000 reboot every time to join wireless devices
Are you saying if you hook up bring in the new Wi-Fi device you need to reboot for it to be recognized? Are using WPS?
12/10/2017 6:19:36 PM • NetGear WNR2000... • Answered on Dec 10, 2017
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
6/10/2016 2:03:40 AM • NetGear WNR2000... • Answered on Jun 10, 2016
Netgear49 will not recognize all websites
There are setting is all the browsers to protect kids. There is also a screen in Linksys and Cisco router configurations where you can turn off access to specific websites such as Facebook. It could also be the website you are trying to get is having technical difficulties or owes money to his host. How to Use Chromes Parental Controls Feature
5/2/2016 7:42:31 PM • NetGear WNR2000... • Answered on May 02, 2016
I lost my username and password to reconnect to my
Hold in the reset button for 30 seconds, unplug the router for 30s while keeping the reset held, and plug it back in, still holding reset in for another 30s. Then hook an ethernet cable from it to your computer and open up http://192.168.1.1 in your web browser. You can then log in with username "admin" and password "password" to reconfigure the network with a new username and password. http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
5/1/2016 2:34:48 AM • NetGear WNR2000... • Answered on May 01, 2016
How can I reset router automatically?
There is a small reset button in the router that you will need a paperclip or pin in order to reach it. If you hold the pin in for about 25 seconds (making sure you are actually pressing and holding the button in) you should find that the router is reset to default.
4/16/2016 8:51:18 PM • NetGear WNR2000... • Answered on Apr 16, 2016
2answers
I do not have a reset botton on the router how do I reset it?
unplug it from the wall, wait 30 seconds or so, plug it back in.
2/23/2016 9:26:40 PM • NetGear WNR2000... • Answered on Feb 23, 2016
Netgear extender install wn2500rp
Configure the extender as a bridge.
3/11/2015 9:14:58 PM • NetGear WNR2000... • Answered on Mar 11, 2015
Authentication error occurred comes up on my samsung galaxy s after i have been on the internet for a while, connection also drop of on the laptops as well. when we reset the router everything works a
The router is dropping the link due to the MTU being set to 1500, if this does not match your ISP's MTU, it will eventually fail as it will get out of sync.
3/9/2015 4:49:27 PM • NetGear WNR2000... • Answered on Mar 09, 2015
Infinite lease period
Page 25 will change idle time to router to "always on" There is no way on the router to set the DHCP lease time. See manual http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
3/8/2015 7:35:55 PM • NetGear WNR2000... • Answered on Mar 08, 2015
Trying to port forward a web port, media port, and phone port to an ip address for security camersa
1. Select Port Forwarding/Port Triggering under Advanced in the main menu. 2. From the Service Name list, select the service or game that you will host on your network. If the service does not appear in the list, see the following section, "Adding a Custom Service." 3. In the corresponding Server IP Address fields, enter the last digit of the IP address of your local computer that will provide this service. 4. To the right of Server IP Address, click Add. The service appears in the list in the screen To define a service, game, or application that does not appear in the Service Name list, you must first determine which port number or range of numbers is used by the application. You can usually determine this information by contacting the publisher of the application or user groups or newsgroups. When you have the port number information, follow these steps: Adding a Custom Service. 1. Select Port Forwarding/Port Triggering under Advanced in the main menu. 2. Click Add Service (see Figure 5-1 on page 5-7).The Ports-Custom Services screen displays. 3. In the Service Name field, enter a descriptive name. 4. In the Service Type field, select the protocol. If you are unsure, select TCP/UDP. 5. In the Starting Port field, enter the beginning port number. • If the application uses only a single port, enter the same port number in the Ending Port field. • If the application uses a range of ports, enter the ending port number of the range in the Ending Port field. 6. In the Server IP Address field, enter the IP address of your local computer that will provide this service. 7. Click Apply. See the rest of the manual here. http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
3/8/2015 7:22:04 PM • NetGear WNR2000... • Answered on Mar 08, 2015
WNDR3400v2
Access a website such as www.google.com
3/8/2015 6:13:04 PM • NetGear WNR2000... • Answered on Mar 08, 2015
Can not connect chromecast to netgear wnr2000 v3
You need to follow the instructions of connecting the Comcast to a PC first, and setting it up. Then you connect it to the TV and access the router wirelessly.
3/8/2015 6:12:26 PM • NetGear WNR2000... • Answered on Mar 08, 2015
You need to follow the instructions of connecting the Comcast to a PC first, and setting it up. Then you connect it to the PC and access the router wirelessly.
3/8/2015 6:11:41 PM • NetGear WNR2000... • Answered on Mar 08, 2015
Netgear router stopped working
The router is stuck in test mode. You need o contact Netgear support, see manual. http://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf
3/8/2015 2:38:56 PM • NetGear WNR2000... • Answered on Mar 08, 2015
NetGear WNR2000 Wireless Router Logo
347 questions posted
Top NetGear Computers & Internet Experts
Marvin
Marvin
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
find out netgear71 password
  • Computers & Internet
